There is no spark in Derby 99
14 years 3 weeks before #22427 by manual-mecanica
There is no spark in Derby 99 published by Manual-Mecanica
hello everyone.
I just bought a Derby 99 but the coil burned. And you change but still does not spark. Also check the hall effect and everything works well active the injectors but spark no, now this had already happened to me but in a newer model 2005 and in some other VW. And in some occasions a fuse is also flushed that cuts the spark plugs only but the problem I have is that I do not have the user manual of this 99 model and for which I do not know where this fuse in this model since it changes physically the fuse holds, in addition to that they have put hand to the beast and have some adaptations.
Could anyone guide me with the location of that fusuble?
thank you
14 years 3 weeks before #22428 by manual-mecanica
Manual-Mecanica Answer on the Re: There is no spark in Derby 99
hello !
In this same page there is an electronic injection manual where most of the electrical engine circuits of European cars come out, among those your car, which appears as VW Polo!
14 years 3 weeks before #22433 by manual-mecanica
I uqe you review them all to be ultra sure that this is not the problem, anyway you take less time to check everything with a tester than to find the manual. The coil is current?
14 years 3 weeks before #22438 by manual-mecanica
Thanks for your answers.
In fact, check all the fuses and relaxes of the panel, but the problem I have is that I mention it is seen that they have put hand very badly, since there are spliced ​​cables and others more cut and that is why I want to check the manual to be able to check line by line.
greetings
