Hello everyone, yesterday circulating with the derrepent saxon, the chivato of motor fault was lit the car gave some pulls and stopped. It cost me about 10 minutes to be able to rranch again but the light did not take off, today the failure still persists and it costs him enough to start. Please you can tell me what the problem is, it is that with the crisis any savings is necessary thanks and greetings
The best thing you can do is make a scanner, because we can all tell you where to go but the failure can be for a number of factors, it is the most fast and faster, now if it costs you a lot the starting can be from a problem of spark plugs to a bomb problem, depending on whether it costs you the first Arranke or all the messing, in cold or hot, if you give us more data we can tell you better where you are lucky and greetings.
Look according to what you say is very likely that you have a water problem in the Oil gas filter. I also do not recommend changing it if it is not in a lubricating you have to purge well and they usually have air problem.
