MONZA 99 TRANSMISSION PROBLEMS
14 years 3 weeks before #22437 by manual-mecanica
Problems with Monza 99 Transmission Published by Manual-Mecanica
Peocupada because I have 5 months with my car in the workshop for transmission failure and it remains the same already pays the mechanic and nothing that I leave well! Now they say that they set the transmission badly and that because the Overdrive cable is melted, the Scaner does not read and it is probably that detail of why my car does not start the speed changes in time the main fault is in the 3rd and direct because the 1 and 2 if it pulls as well as the reverse ... what do I do ??? Now they sent me to get such a module that goes inside the shell near the foot of the Baston ... it's true help me !!!
14 years 3 weeks before #22458 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Monza 99 Transmission
When the problem is the automatic exchange boxes, the diagnosis without being ahy to see it is usually very complicated, now if they already repaired it and it does not stay well you have the warranty so that they repair it again at no cost, now the module can be one of the failures but it should be made a cheko of all the components of the valve body, brake symptoms, filter Even to take to the experts in boxes and not to any mechanic, since they are not very easy to repair and usually do not find the failures until they change everything, the cable has nothing to do only connect the OVER and now.
