My Jetta 2005 clutch pedal was left
14 years 3 weeks before #22442 by manual-mecanica
The 2005 Jetta Clutch pedal was left published by Manual-Mecanica
The pedal stayed down and I do not know what it is, it stays down and no longer entered any change, on that same day it worked again and I moved it some 2 km and everything is fine, but in the course of the journey the same thing happened and now if I no longer raise, which can already be changed the clutch pump but it remains the same, it does not smell of burning or anything, it will be the cylinder that is in the transmission or Clutch?, I expect some response thanks in advance ...
14 years 3 weeks before #22459 by manual-mecanica
Manual-Mecanica Answer on the Re: The Clutch Pedal of My Jetta 2005 was left
If the pedal does not return and you have a hydraulic clutch, Primro Czechs the pump, then the auxiliary cylinder and if your thrust bearing is hydraulic that can be the problem, ovio eliminating the other two causes before lowering the box, disc is not by very spent that the pedal returns, it is the fault of some of the factors that I mention, loop if with the regulation of the vast. Czech pedal and luck.
