HIUNDAY ELANTRA FAULT CODES
14 years 3 weeks before #22529 by manual-mecanica
HIUNDAY ELANTRA FAULT CODES PUBLISHED BY MANUAL-MECANICA
Hello, I have a problem (Obd II) I throw this P0103 code (high entry into the mass or volumetric flow circuit) I suppose it is a valbule but I do not look for it in the Hiunday Elantra year 2001.
14 years 3 weeks before #22536 by manual-mecanica
Manual-Mecanica Response on the Re: Hiunday Elantra Failure Codes
Hello dear. The DTC or Averia Code that the Obd II throws you, refers to the air dough seam O (MAF, that sensor is located in the admission duct, between the air filter and the admission collector. What is not raised if your vehicle, use MAF or MAP, in any case the MAP sensor, it measures the absolute pressure of the admission collector Fuel air, if leaving aside the other sensors.
14 years 3 weeks before #22568 by manual-mecanica
It is also gathered as a flow and what ABS says, in the Elantra depending on the engine is used in the air hose that goes from the air filter to the multiple of admission, is mounted on the filter body and has a 4 -pin black clin
14 years 3 weeks before #22589 by manual-mecanica
Hello, the sensor found as much as I could have to clean it and change the air filter. sorry my ingnorance is this type of problem that is suspended. thank you.
14 years 3 weeks before #22592 by manual-mecanica
You have to check it see if your body is not harmful and that, check the connector and earth's current.
