Fiat 2.8 Sofim Colat Remove the collectors
14 years 2 weeks before #22731 by manual-mecanica
Fiat 2.8 Sofim Colat Remove the collectors published by Manual-Mecanica
If someone makes a hand because I broke the distribution strap and I need to lift the cylinder head and the main problem I have in the escape collectors
14 years 2 weeks before #22739 by manual-mecanica
Manual-Mecanica Response on the Re: Fiat 2.8 Sofim Coca Remove the collectors
What is the problem with the collector?
14 years 2 weeks before #22744 by manual-mecanica
My problem is that if I have to lift the cylinder head from where I should cut the collectors. Because if I do it from the union after the turbo, I believe that the butt would be very difficult to extract with the whole set and if I have to cut by top of the turbo, of course, this fucking would have to disassemble the alternator and pulley to access the screws on the right
and split the left part of the turbo to access the left -wing screw.
14 years 2 weeks before #22765 by manual-mecanica
They are usually disassembled from the couplet that is immediately under the multiple and the admission is left, so they all will have to leave just like that.
