Astra 2006 does not march (new line)
14 years 2 weeks before #22745 by manual-mecanica
published by Manual-Mecanica does not march
How about friends !!!
Well look I have this problem with an astra 1.8 manual transmission.
It does not go directly from where the key is inserted have already checked a modulus K is in the steering wheel and is in perfect condition, of all the fuse holders and the key is coded as well as the board. The problem lies in the fact that it does not pass current to the spark plugs as well as the gasoline pump does not try to try scannerus with the tech for GM to know about a possible programming of some module but I throw error cannot read it. What should I do? In advance, all the comments and the time to read are appreciated.
14 years 2 weeks before #22766 by manual-mecanica
Manual-Mecanica response on the Retra 2006
Friend usually when there is no spark or fuel, it is because of a relay, fuse, or some motor land that communicates with the aboard computer, the sensors have nothing to do, Czech that everything is connected to start, it happened to me with a corsa and it was a cable cable reign.
