Light Airbag is caught renault megane
14 years 2 weeks before #22749 by manual-mecanica
Light Airbag is caught renault megane published by Manual-Mecanica
The airbag light does not turn off in a 2003 Renault Megane, they already put the scanner and found no novelty, when moving the cables located under the chair it goes out and after a moment it sets again. They have already reviewed it but nothing to correct the problem
14 years 2 weeks before #22760 by manual-mecanica
Hello FACC_01, you have to eliminate the connectors and weld the cables. Do it without problems, one cable behind another so as not to get on, salary them with tin and isolate them well and you will see how the problem ends. And you will say how it went, Salu2 ...
14 years 2 weeks before #22771 by manual-mecanica
Indeed if you move the cables and go out it is only contact problem, nothing more,
