gasoline marker
14 years 2 weeks before #22756 by manual-mecanica
gasoline marker published by Manual-Mecanica
Hello friends I have a S-10 Chevrolet. The gasoline marker when I put the small small key and returns to vacuum and already underway does not mark any idea or suggestion about this problem in advance thanks. Oh the velocimeter does not mark the rpm thanks.
14 years 2 weeks before #22758 by manual-mecanica
Manual-Mecanica response on the re: gasoline marker
Hi Raponcho, did you check the masses that feed the picture? Another problem can be in connections, which are making bad contact. You will count, Salu2 ...
14 years 2 weeks before #22769 by manual-mecanica
Czech what the fellow podasetos says when putting the key feeds with the ground can be the problem also to check the pump connector put a direct cable to the ground to the connect of the pump and see if it lifts if it does is the comb or pump archer.
