Nissan chassisbina motor rings 2001
14 years 1 week before #22931 by manual-mecanica
If when rectifying the cylinders you have to put rings at 0.20 the pistons should be yes or if 0.20, they work together if there is no game and it is worse that I do not see anything.
14 years 1 week before #22934 by manual-mecanica
Hello, your engine is diesel or gasolinero
14 years 1 week before #22935 by manual-mecanica
first compression
diesel Compression 0.20
mm oil 0.10 mm
If it is
first compression
gasoline 0.10 mm Compression Second Compression
14 years 1 week before #22952 by manual-mecanica
It's gasoline engine, I think it's 2.4, thanks `for your help
14 years 1 week before #22954 by manual-mecanica
Confirmed, if they are in standard, you have to ring in standard, it does not matter if you have that wear, because if you put the rings in 020 ", you will have problems, the ideal would be to rectify, but if for reasons of $$$ it is impossible, then it only works even if it would be a temporary solution in which tickets come out to rectify, in whether the rings are not expensive, so you would take away the problem that the problem would not take the problem. I know where are you in, but here in SLP I know a rectifier that is not expensive.
