Renault Master 2.2 dci 90 does not start hot
14 years 3 days before #23094 by manual-mecanica
Manual-Mecanica Response on the Renault Master 2.2 DCI 90 does not start hot
Hello, it would not be bad that you try to throw motor oil in the fuel tank, fill the tank and add engine oil (clean) this would have the effect of lubricating the tips of the nozzles does not make more smoke does not harm the injection does not have any power loss but if it reduces problems added to the gas-oil that you take some you carry excess of sulfur
14 years 3 days before #23096 by manual-mecanica
I will try to do what you tell me to have such
14 years 3 days before #23098 by manual-mecanica
Hello if the precion pump is mechanical you can prompt cooling it with water when the fault is present and rule out that the wear of it is the fault
14 years 2 days before #23117 by manual-mecanica
The pump is high pressure The system is Common Rail
13 years 11 months before #23235 by manual-mecanica
Thank you very much for the help provided, I have already solved the problem
the failure I had was the regulating valve of the injection ramp
