Air conditioning problem
14 years 1 week before #22937 by manual-mecanica
Air conditioning problem published by Manual-Mecanica
Hello everyone, it is the first time I send a message in this forum and my problem is that my car's air conditioning (Peugeot 206 ´99 xtd 70 hp), stops and turns on continuously when the car is in Relay, when the car is running perfectly, it has already been tested by uploading the release but it remains the same and the thermostat is changed, I do not think, I do not think, mechanics Thanks, a salu2.
14 years 2 days before #23120 by manual-mecanica
Manual-Mecanica Response on the Re: Air conditioning problem
This happens to me with my Peugeot 306.
First I changed the battery, paresia that had no pontencia, it was not the battery,
then the joints of the inyestors, it seems that the mexcla of gasoline is impoverished and that is why the slowdown fails, the slowdown began to work well.
Then I had to change the condesor had gas losses of the air conditioning, the air began to work.
Then the air regulator that is next to the carsary is broken and frozen.
Then the regulator or vavula of the air that is the one that makes the air cool when the temperature rises inside in the car, this valve is the one that makes the relief begin to rise and lower, it has been a lot today has passed me again and that it has happened to it, that it has been left without gas, I believe that the Peugeot are total vasura fail everywhere.
14 years 2 days before - 14 years 2 days before #23126 by manual-mecanica
In order to help you, you would have to see more information about your problem, that is, for example;
Why climb the idle if the air conditioning equipment does not depend on motor revolutions ...
second is your equipment or generic ???
It is not crankccing or much less bad milk! But a battery will never make you fail the air conditioning because the vehicle on in idle or runs still has 14 volts that is to say that the battery will never make voltage variation, the alternator is done ...
Latest edition: 14 years 2 days before by .
13 years 11 months before #23276 by manual-mecanica
If the system is heated, to automatically reach the programmed temperature, if it is not heated, you will have to check the gas load of the air conditioning circuit, anyway if you put it to cool to the maximum would not have to stop if the gas load is correct.
