Slow motion
14 years 4 days before #23083 by manual-mecanica
Manual-Mecanica Response on the Re: Readrix
Add, that from 1100 rpm it is no longer noticeable, and if it is hot, it almost did not. If it is cold and the A/C compressor enters the problem.
14 years 2 days before #23146 by manual-mecanica
It can be that it is working in three cylinders or that you have a coil in poor condition
14 years 19 hours before #23198 by manual-mecanica
There is a cylinder (the left at all looking at the front car) that if I remove the spark plug cable the engine is destabilized less than doing it with others, but it can be a form of engine compensation. The coil I think is fine since I notice the discharge of tension when I approach the cable to the spark plug. I no longer know what to look at the truth. Anyway thanks for your answers.
14 years 3 hours before #23225 by manual-mecanica
Your model is with an independent coil by cylinder, or use one with cables for all cylinders?
13 years 11 months before #23247 by manual-mecanica
You can have a failure in some spark plug or in some cable, if the spark plugs have many km. I would change them before getting older expenses.
