step -by -step
14 years 10 hours before #23190 by manual-mecanica
Manual-Mecanica Answer on the Re: Step by step
Nop, Lord Fiat's step is only used on a decline to keep the release, if you have the Ford type then, so you must be very clear if it is a step by step, or an iac etc, put a photo if you do not know and answer you.
14 years 2 hours before #23201 by manual-mecanica
It is, an IAC is an air control valve
14 years 1 hour before #23205 by manual-mecanica
Friend, that is a step by step, if you do not have continuity it is burned and you have to change it, but try it well before because it is rare that there is no continuity in any pin, greetings. :)
13 years 11 months before #23226 by manual-mecanica
SENSOR SENSOR ACTUATOR, THE WHAT YOU HAVE IS OF THE MAGNETTI MARRELI OR BOSCH DOES NOT WORK IN HIGH ONLY IN LOW, ONLY BY CURIOSE AS YOU CLEAN?
