Stratus 99 problem
14 years 1 day before #23155 by manual-mecanica
Stratus 99 problem published by Manual-Mecanica
My car has the problem that it loses acceleration, I went out the end of the cemana and when it reaches 8 it is pulling and the velocimetro goes to zero if I do not release it can follow anything more that and still running but if I release a little the accelerator it goes out complete It reaches 100km/h nothing happens but as soon as you stop a high or lower the speed does the same thing is blew and it goes out I must tell you that when it does that it turns on the yellow focus of Chek Energy and a red focus that in the manual of the ususrium says that it is that of the alarm I already changed 2 censors a censor of oil and injection.
14 years 22 hours before #23184 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Stratus 99
Did you make a scanner to your vehicle before changing sensors? What code do I throw the scanner?
13 years 11 months before #23520 by manual-mecanica
Compadre I had the same problem, I change the complete distributor, it may be just the lid. The price of the detriment is Carisimo I recommend that if you are going to buy it you do it by eBay and get someone to install or do it yourself, it is difficult.
I hope I have helped you
