Fiat Ducato
14 years 1 day before - 14 years 1 day before #23156 by manual-mecanica
Fiat Ducato published by Manual-Mecanica
I have a Fiat Ducato 2.5 120 hp. From 2008. The problem I have is that when I reduce to stop in a Semaforo or Stop, there are even times there are times that I stop and when I have the air conditioning it is accentuated more
Last edition: 14 years 1 day before by .
14 years 12 hours before #23185 by manual-mecanica
Manual-Mecanica Response on the Re: Fiat Ducato
First Czech the current that sends the alternator, if it is fine, perform the admission body and the IAC or step -by -step motor as you have mounted on your vehicle, also check the air filter.
