Ford Ranger 2.3 Year 93
14 years 1 day before #23160 by manual-mecanica
Ford Ranger 2.3 Year 93 published by Manual-Mecanica
I have a Ford Ranger year 93 2.3, I only change the distribution band, change the spark plugs and clean the injectors but now it does not send spark plugs only send the injectors, I want them to help me with the electrical diagram of the Hall effect CKP, as I check if it is worth or not, it is four cables and I want to know how it is the connection to which the connection is The connection of the DIS module as I check if it is worth and the electrical diagram, I would thank you enough if they helped me with that ...
14 years 12 hours before #23188 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Ranger 2.3 Year 93
Friend if it is of effect hall you will have to put a diode connected in series to be able to try, the negative of the diode to signal and the positive contact current in the wiring if it flashes with the start then is fine, but if you did not move anything and that everything well installed, I check fuses perhaps any.
14 years 10 hours before #23193 by manual-mecanica
apology Pana, which you tell me about the DIS module that it carries in the admission, it can also be that or not and how it is checked by it in a diagram that the CKP comes out to the module, he replies.
13 years 11 months before #23223 by manual-mecanica
If you carry a cable that sequences the current, it is like the platinum of the distributors but if it is well tuning, and you did not touch anything it is difficult to spoil, check the same thing you did and by the places you walked, to rule out that you find or disconnected something without wanting the lands well placed and where this corresponds this is very important.
