Reheating of a GM V8 350 Chevrolet
14 years 19 hours before #23178 by manual-mecanica
Reheating of a Chevrolet GM V8 350 posted by Manual-Mecanica
First of all I thank those who read this problem and much more if they give me the solution, this is um GM V8 350 according to my research The year is what I would not know but I think it is 85, a general repair was made a general repair PQ was already overheating before and we thought it was a problem of the packaging, also that time that the truck did not move, repair of water pump of water. Building the engine and 10 minutes to the top, it was thought that it was a problem with the rings, but the right light was given, from there we saw that its cylinder head had very small water ducts in diameter, I sent to prepare packaging with large holes, and I endure more than 1 hour but when it took to try again, and from there there is an issue that I have in doubt, when I take a question, when I take the cover, when The engine starts, it is seen that the water circulates, but when you stop accelerating, it is seen that the water goes out to presignment, and this is, I cannot give it a solution, the only thing that I have left is to get a radiator with vertical gutters and see if it helps to pass the water faster, I appreciate the solutions you provide. PDT: It has no thermostat and its drive is by Correa (belt)
14 years 10 hours before #23191 by manual-mecanica
Manual-Mecanica Response on the Reheating theme of a Chevrolet GM V8 350
Is that model with electro -ventilator or with thermventilator? It could happen that the viscoso is spoiled.
14 years 5 hours before #23196 by manual-mecanica
The fan is driven by Correa and has nothing electric
13 years 11 months before #23224 by manual-mecanica
Ok have you tried if that fan works correctly? When the self heats should turn stronger, if it does not take it and translate it with a cross bolt or save it and install it and test it to see if it is heated.
13 years 11 months before #23256 by manual-mecanica
It could be the lack of the thermostat according to where it is placed cannot be removed, since where the hot water comes out of the side is the cold water inlet only separated by the thermostat and if it does not have the pump's own aspiration it absorbs the water that comes out of the engine instead of taking the one that comes from the radiator
