step -by -step
14 years 2 hours before #23202 by manual-mecanica
Speaker step by step posted by manual-mecanica
I have a question with this iac valve is from a Fiat Siena 1300 fuly inject 4 pins but it has no continuity between them it will be that this valve helps the car to develop more when it passes the 100 km x hour or even more, in reality so that it is designed I want to know I am from Venezuela here
14 years 1 hour before #23207 by manual-mecanica
Manual-Mecanica Answer on the Re: Step by step
Hello, how do you say the IAC sensor is an actuator that controls the operation in Readi, allows us to regulate the amount of air, by putting the engine running allowing slightly accelerated to gradually decrease the acceleration, I leave this link something will help you.
13 years 11 months before #23252 by manual-mecanica
grace is the same valve that of the video I boy to provar
