- Thanks received: 1
06-19-2025 Hits: 916 Technology
Do not guide yourself because of the diagram because this is not the kit to lock the distribution: the rod in L for the crankshaft; The E E -shaped plate for the lavas tree, it is looked back from behind you have to remove the valve lid and the bolt is for the injection pump, very important: the gear of the camshaft is conical is to disclaise it, loosening it loosening the screw 1 turn and giving it a hammer blow.Claudioman wrote:
