Renaul Megane II does not turn on. If it starts
13 years 11 months before #24099 by manual-mecanica
Apart from what you have checked, you have taken into account the vehicle immobilizer, how often the flash of the LED is used in the center of the instrument board or if it turns off when you give it start
13 years 11 months before #24176 by manual-mecanica
How such,, I think knowing what the problem was once I had a very similar problem, bothering the ignition, it was starting but it was delayed or the idle was unstable or turned on and the starter engine starting. I do not know what the technical name is but it is like a black box at the entrance of the admission is the one that controls the idle and sends the different positions of the accelerator something like the TPS ,,, there are the identification easily the clearing and the she was full of charco With that problem ...
13 years 11 months before #24178 by manual-mecanica
The APPEARATIC or Black Box is called Tac or ECT and has to be very careful with the manipulation of this element that preferably with a disconnected battery since the communication of this element is by multiplexed network.
Do I have the CKP signal?
13 years 11 months before #24194 by manual-mecanica
I already sent the fusera to repair. As soon as I have it ready and the mosnte tells you what happened. Thank you.
13 years 10 months before #24511 by manual-mecanica
Well friends repair it fusera, the car turns on but still has a failure in idle, when the accelerator is drowned. I pass to review the TAC or etc. such as they reomck Crazy and Daninovato. How much advances.
