Motor Cascanele
13 years 11 months before #24091 by manual-mecanica
Motor Cascaneleo Published by Manual-Mecanica
I have an automatic impression the engine Case when taking normal temperature the engine is newly adjusted and not out of point
13 years 11 months before #24111 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Cascanele
How many kilometers do you have tours after the adjustment, and what year is the printed one, eye with the regulation of valves.
13 years 11 months before #24142 by manual-mecanica
The Impreza is from the year 96, and has 800 kilometers traveled after adjustment, but the car began a few days behind with the bells
13 years 11 months before #24143 by manual-mecanica
Partner verifies what happens with the motor lubricant it may be that some connecting rod metal is being squeezed due to lack of lubrication and the metal tends to turn, it can also be the engine temperature not from the radiator to me it happened to the motor temperature with a Daihatsu Charade Sg of the year 94 and it was only the cooling system the cylinder head had a picket and lost pressure the circuit ... I hope it serves you ...
