Ford Ka does not turn on
13 years 11 months before #24150 by manual-mecanica
Ford Ka does not turn on published by Manual-Mecanica
I have Ford Ka 1.6 that does not turn on. The lights work, alarm. The coil was changed since it was short and the board fuse had burned the engine but not pulse. The Scaner does not indicate any failure. Please have any help since I provide with everything and I can't find the fault. Thank you.
13 years 11 months before #24157 by manual-mecanica
Manual-Mecanica response on the Re: Ford Ka does not turn on
Check the crankshaft captor is in charge of sending the spark signal, and Claro Checa that exists the spark in the spark plug cables.
13 years 11 months before #24159 by manual-mecanica
If you refer to the wheel, take it out and test it and go ok. Current arrives by the two channels but there is no sign on the central channel. At the moment Kemados is not the emergency Blokeo system this OK. They turn on lights and board the Scaner does not detect any fault. I don't know what to do .....
13 years 11 months before #24171 by manual-mecanica
But if there is no sign on the middle channel then it is not right, I am referring to the magnet captor connector.
13 years 11 months before #24173 by manual-mecanica
Friend, check the pump, if you have a spark, the signal of the captor with an oscilloscope, but if you say that it does not send pulses the problem can be in the ECU
