WOLSVAGEN PASSAT OIL PRESSURE 1.8T 2004 20VAL.
13 years 10 months before #24175 by manual-mecanica
Anille a engine of these recently, but now I have a problem that I find not explanation, the oil pressure witness is turned on and tells me to stop the engine immediately, change the pressure pear but it remains the same as strange is that it does not turn immediately if not when the car is already at work temperature and when one walks it for a while ,,, Pressure in Irate
13 years 10 months before #24202 by manual-mecanica
Manual-Mecanica Response on the Re: pressure Wolsvagen Passat 1.8T 2004 20val.
What oil filter did you place?, in these engines you must use the double valve, and if the problem continues, replace the oil pump, this is the solutions that have worked in these engines,
13 years 10 months before #24248 by manual-mecanica
Ok, I will review the filter that installs tomorrow, I remember that it is one for 10000km ... but I am not sure if it is double valve ,,, thanks for your answer, it barely have a fact I warn you ... I hope it simply be the filter.
13 years 10 months before #24289 by manual-mecanica
Czech about the filter but before accusing the Czech pump that the oil suck is not obstructed, to discard the easy and then the most complex as the oil pump
12 years 4 months before #40508 by manual-mecanica
Hello look xfavor I need to know that kn your passat and k ami the same thing happens to me the problem and ps do not find x fa kien see this help me is urgent thanks thanks
