Toyota Corolla 2004 with bad battery ..
13 years 11 months before #24212 by manual-mecanica
Manual-Mecanica Response on the Re: Toyota Corolla 2004 with a bad set.
Hi, in some European Toyota models they have hooked next to the positive terminal a plastic armored box and there are fuses that to repair them you have to change the box or weld them, perhaps in the American models they do not take it. While your model carries these fuses in the engine compartment box, they are fuses that are screwed and to change them you have to disassemble the box.
I send some files in JPG.
Greetings
13 years 11 months before #24213 by manual-mecanica
PRDON, I have left a file
13 years 11 months before #24214 by manual-mecanica
13 years 11 months before #24215 by manual-mecanica
I had already changed it ... it was the alternator just .. They burned all the diodes .. it is the system that is screwed ... very good scheme you have .. well realistic ..: Woohoo: I have already solved the car and it was perfect back ..
