Change Peugeot 405 cylinder lid joints
13 years 11 months before #24192 by manual-mecanica
Change Peugeot 405 cylinder lid joints published by Manual-Mecanica
Hello, I need if someone can guide me on changing cylinder lid joints 405 1.9 diesel mod.97 raised temperature to break a radiator hose, the joint is breathed.
13 years 11 months before #24203 by manual-mecanica
Manual-Mecanica response on the Re: change cylinder lid joints of the Peugeot 405
Hello if it is the engine that also mounts the 306 that engine has an XUD9 denomination, the tuning is very easy that engine has an XUD9 denomination. To perform it you must mount a pin (you can wear an 8 mm screw) in a housing that has the gear of the camshaft, two pins (or 8 mm screws) in the injector pump and between the starter donkey and the motor of the motor in the Blok Screw with the tip of the crankshaft, having the four pins placed the engine is ready anything I wrote again I hope it serves you ..
13 years 10 months before #24245 by manual-mecanica
Thank you Juan for your comment, what you describe is before taking out the lid or after changing the joint? If the set -up is after change, forgive for my lack of knowledge, I like the mechanics and I want to know more about the subject of my Peugeot to know if the mechanic does a good job.
13 years 10 months before #24247 by manual-mecanica
Hello friend, the description that Juan made is excellent. I recommend that you make the references to be ready before disassembling so it is easier to set up later
13 years 10 months before #24267 by manual-mecanica
Thank you very much for the advice, I hope to tell you when the repair ends, greetings
