Nisan Patrol rear brakes
17 years 4 months before #2564 by manual-mecanica
Manual-Mecanica Response on the Rear Nisan Patrol Rear brakes
Hi Rocco, having if this weekend I encourage and try it what you tell me. The drums that I know have never been rectified and the shoes put them new. Then I understand that the drum is fine and the peaceats well mounted and tight kon to a tooth wheel that is in the lower part (as according According to the wheel, it slows off less, then would the drum be deformed? Another question now approved, is an old patrol, I would not know how I empty and put it new to your nvel kon the density that says Nissan, will the gearbox be fucked and is that very fucking to fix? Well thanks for everything, I hope your answer.
17 years 4 months before #2566 by manual-mecanica
Do it as Rocco tells you, which is the right way to adjust the rear brakes, but when you mount it, the drums and change them from side, the right to the left side and the other for the right, which also helps to match the brakes
