- Thanks received: 1
06-19-2025 Hits: 987 Technology
Kikemec wrote: Friend the catalyst is or not, I have independent of good or bad status, do not turn on the check warning, only the components related to the injection and ignition system are lit, that on the one hand if you kieres turn off the light you take out the board and remove the ampoup, in some vehicles if you do this you can generate even more problems, to the point that they do not start, you will not start. Always if you do not repair the problem, it is no solution that you say, there are you if you do it.
