Electric scheme Peugeot 207
13 years 10 months before #25010 by manual-mecanica
ELECTRIC SCHEME PEUGEOT 207 Published by Manual-Mecanica
Very good day.
I tell you that I am having problems with the electrical system, punctually with the high lights, since they are caught until when the car is off. I already control the fuses and are not. Someone could give me a hand with this topic
greetings
13 years 10 months before #25025 by manual-mecanica
Manual-Mecanica Response on the Re: ELECTRIC SCHEME PEUGEOT 207
I think you should try by removing the reliars ...... one by one takes it away and you look if the lights go out ... if so you are looking in that same fuse box for a relay with the same number of part and probas ...... prayers 2 our father and ready ... to buy another relay ....... luck
13 years 10 months before #25027 by manual-mecanica
I hope that is that I will only try and we will see a lot thanks for the answer
13 years 10 months before #25049 by manual-mecanica
I have seen that problem in the Peugeot and is usually the fault of the telecomando is changed and now, now there are some that are divided into two parts and others with are complete.
2 years 3 months before #54411 by manual-mecanica
Good morning,
Could you tell me if there is any reverse that controls the horn of a Peugeot 207? I have looked at the fuses and they are fine, but the horn does not work.
Alvaro Cruz Cruz wrote: I think you should try by removing the relies ...
Thank you so much
