- Thanks received: 1
06-19-2025 Hits: 1004 Technology
Guanabacoa01 wrote: Greetings friends, I have a consultation/problem about a Volkswagen Golf 2.0 LTS 2006 vehicle, this vehicle does not accelerate more than 1500 rpm, I put the scanner and gave me 3 fault codes 17976, 17987, 17953, my scanner is a launch x431 II ..
Code 17976-P1568: Butterfly Control Unit -J338- Mechanical Fair.
Code 17987-P1579: Adactation not initiated from accelerator valve control -J338-.
Code 17953-P1545: Defective butterfly valve control.
It will be that the problem is in the electronic acceleration body, the acceleration body will be badly calibrated, the owner says that he previously checked the same failure but without result, I removed the acceleration body and did cleaning but the problem continues, I would appreciate any help to this problem.
