Ford Focus 2001
13 years 10 months before #25160 by manual-mecanica
Ford Focus 2001 published by Manual-Mecanica
How, I have a 2001 Focus, I want to know if this has happened to someone: 1. The velocimetro suddenly stops working and when the engine is completely stopped. 2. Allow to circulate on a slope the car loses strength and I can not rise it.
I await your comments.Salu2.
13 years 10 months before #25176 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Focus 2001
It is probably the time band, at least he is unveiled to walk every 50,000 miles, don't you set the yellow lus? Did you already walk spark plugs and everything related? Check out the engine pressure, do you say this more constant when you turn on the A/C? , you miss Cold, an air manger is loose, the sensor that regulates the air, because you do not turn off when you bring it running, right '? Give more information that we can help you, until later
13 years 10 months before #25194 by manual-mecanica
You have to get codes first to have a parameter to work. This will give you the guideline to know why velocimetro stops working. If the velocimeter does not usually work the PCM or the TCM blocks the box and stays at a single non -first speed, it is generally 3rd and that is why the loss of strength that is felt. Take out codes and tell us so we can help you more.
