Motor problem
13 years 10 months before #25254 by manual-mecanica
Manual-Mecanica Response on the Re: Motor problem
Hello, my advice is to provise first.
change all filters and if possible fuel.
If this does not give results to review otrs more specific problems
Greetings of Enrike
13 years 10 months before #25281 by manual-mecanica
Usually in oil engines it is relatively simple the big problem is that it is expensive and error, first it measures compression, if you are good, the correct setting and look with special care that the pump does not move and it is well fixed in its place, then if this is fine you take out injectors the clean and calibrate the tests if it goes well it is the fault of the pump, usually the bomb bothers in high it You see working temperature.
