Blue smoke
13 years 10 months before #25261 by manual-mecanica
Blue smoke posted by Manual-Mecanica
Hyundai Terracan 2.9 Crdi smoke problems is accelerated and stops the engine in relash and smokes once it is up
13 years 10 months before #25262 by manual-mecanica
Manual-Mecanica Response on the Re: Blue Smoke
PA Make to check injector tips Change diesel filters by the original vehicle check if there are no air inputs in the dark blue smoke are rings that is that it is happening a lot of oil to the cameras of the pistons
13 years 10 months before #25269 by manual-mecanica
The blue smoke is by the presence of oil in combustion, this is because of the valve seals or for spent rings, when they generally humidly smoke if the smoke is black is the injector pump or injectors, if it accelerates and stops alone, checks air and eye entrances with the admission body that is not very dirty.
13 years 10 months before #25273 by manual-mecanica
I ask: Inreality do you think that some valve are influenced by a turbo engine?
13 years 10 months before #25274 by manual-mecanica
Ethsos Motors bring EGR from the Turbo to the admission and can pass the Turbo to the admission without going through the hoses ....... Of course I think the engine (rings etc.) can be fucking ....... a father of ours and prepares the pocket
