gasoline pump in the tank
13 years 10 months before #25264 by manual-mecanica
gasoline pump in the tank published by Manual-Mecanica
How can I repair the gasoline pump found in the fuel tank
13 years 10 months before #25266 by manual-mecanica
Manual-Mecanica response on the Re: gasoline pump in the tank
Good night, gasoline pumps cannot be repaired that I know, what car is and what motor do? Because you could get another one, it does not have to be the same, just when you set it that the manger does not be doubled because the gas would not pass, until later
13 years 10 months before #25267 by manual-mecanica
It is true you must take it out and replace it, whether original or alternative, it can be adapted but eye with the pound, that is, the amount of PSI that elevates.
13 years 10 months before #25304 by manual-mecanica
Hi Friend Dolo has to replace her for a new one but you have to take into account the work pressure
13 years 10 months before #25313 by manual-mecanica
It is an accent 94 1300cc carbon
