problem by starting in Nissan V16 of `96
13 years 10 months before #25295 by manual-mecanica
Problem by starting in Nissan V16 of `96 published by Manual-Mecanica
The problem is that when giving contact, it sounds like a stuck or something like that and the start is as if it is stuck. This sometimes prowns it.
13 years 10 months before #25343 by manual-mecanica
Manual-Mecanica Response on the Re: Problem by starting in Nissan V16 of `96
Your problem must be linked to the electrical system, prove the ground cables there that someone does not make good contact
13 years 10 months before #25356 by manual-mecanica
Perform a simple test, put a cable from a battery negative to any part of the engine to make dough and start if it is good, it is lack of land if the problem persists, then the relays checks and if it is not solved, take out the start and test it
13 years 10 months before #25403 by manual-mecanica
Check the connections to the starting and battery engine, which are not loose or sulfated, if everything is fine then you are likely to have problems with the starter of the starter engine
