The engine trembles
13 years 10 months before #25306 by manual-mecanica
The engine trembles too published by Manual-Mecanica
I have a 1981 Mustang and has the 302 V8 engine the problem is that it trembles too much and turns off when it passes through a bump or bump
13 years 10 months before #25307 by manual-mecanica
Manual-Mecanica response on the Re: the engine trembles too much
To review, supports, spark plugs, coil cables and distributor, why have you not exo any mechanical work?
13 years 10 months before #25308 by manual-mecanica
Cables, spark plugs, coil, a separate distributor, take many explosions when he warms up
13 years 10 months before #25309 by manual-mecanica
I am only the distributor to the mind, they set, I spent a couple of times that the axis saw different, I explained, if you compared one I came with a couple of degrees of advance or setback, in comparison and that produced that type of failures, not in the same car, but if I saw it kisas tmbn I remain a tooth.
13 years 10 months before #25310 by manual-mecanica
Check the carburetor, the distributor
