Blow in the engine
13 years 10 months before #25382 by manual-mecanica
Blows in the engine published by Manual-Mecanica
Hi, I wanted to see if someone throws me an idea, I have a Mondeo 95 Ghia Motor 2.0 gasoline, and when we accelerate, let's say the accelerator and loose floor and loose, when I immediately heard a blow is heard the safe escape is not because I changed it recently. What can I look at?
Greetings,
Diego
13 years 10 months before #25397 by manual-mecanica
Manual-Mecanica response on the Re: Blows in the engine
It is a blow or a suction that you hear? That is, it sounds like fuuuuuuu or as SSSSSSSSSSSSPPP, if it is suction then the hose and in some cases like Renault it is normal if it blows the only thing that can be is the escape or some junt passes your hand if you feel it.
