problem in two mitsubishi eclipse 95 cylinders
17 years 2 months before #2701 by manual-mecanica
I agree fully, with the SRO, megabaart-1, it is not the kicks that the plobs are sullable converses with your mechanic, whether the save or not cusl is the defect of the veículo, to guess the defend, it is not to save the default, ok a Apro
17 years 2 months before #2726 by manual-mecanica
I tell you, last Thursday morning I took out the workshop car where I was, and took it to another that they recommended, in a couple of hours they told me that everything was fine that the problem is on the computer, so they recommended a specialist here in Guadalajara Jalisco Mexico www.compuauto.com Surround home again, do you run any risk of a larger decomporting by moving it only with 2 cylinders working? What happens that I have transferred it from one workshop to another by rolling because otherwise I would spend a lot in Cruas.
17 years 2 months before #2790 by manual-mecanica
Nothing else you are not going to water it but the first thing I would do would be to exchange the spark plug cables to see if the ones that do not work and stop doing the others do not work and do so if you already do it if you do not check the coil to see if it does not have a short and if you do not have the multimeter do it with another that if it works, do not buy it because then it comes out that it is not and gives courage to spend.
17 years 2 months before #2852 by manual-mecanica
Finally they found the problem to take it to a 5th workshop and finally remain. One of the lines was short, this short caused the computer to burn and the time the coil of damage, just like a relay. The problem is that when repairing the computer it is when making contact with the car the car goes out, they put a small table as an insulator but the heat dissipator needs to be in contact with earth and this is causing the computer to hot, they are already getting a new computer, the car is already working the 4 cylinders
17 years 2 months before #2890 by manual-mecanica
Manual-Mecanica Response on the Re: Problem in two cylinders of Mitsubishi Eclips
By Finnn !!! Van 4 of 4 cylinders !!! It has not been an easy breakdown to see, total, burned computer, 1 of the two burned coils, a short cable hose, the \ "table \" as an insulator so that the computer does not make mass ... go puzzle.
Greetings and hopefully you don't have so many problems again because of a \ "cablecito \".
