I don't know what fuse I burn, but I have the photo.
13 years 8 months before #26803 by manual-mecanica
Hello, I have a Manual Nissan Sentra 1.8 year 2004, I burn a fuse, which depends the start or something similar. When I give contact, the engine has the intensage of starting but does not do so until the battery stops giving strength to the start. I looked at the fuse box and I realized that there was a "cut" fuse, does anyone know what is called? I send you the photo now
13 years 8 months before #26822 by manual-mecanica
The photos are complicated stockings of seeing hahaha but it seems to me that it is the current of arrival, at the rifle that is to say the one that supplies the current rifle you have a bridge with a cable to try and then buy it.
13 years 8 months before #26826 by manual-mecanica
yessss. Thank you very much ... Last night I said with the solution ... It was a 100A fuse ... I cost me US $ 2. Thank you ...
7 years 3 months before #53012 by manual-mecanica
Manual-Mecanica response on the subject I don't know what fuse I bound, but I have the photo.
The fuse is called Master since it is the main one is 100 in charge of supplying the entire vehicle, (replace it) do not make bridge because if there is a short in the system you can burn the electrical installation and without exaggeration you can even set the car on fire.
Successes in your work.
