D21 starts with the injectors outside
13 years 8 months before #27314 by manual-mecanica
D21 starts with the injectors published by Manual-Mecanica
Hello friends,
I tell you that I have a Nissan D21 2.4 2001 Double Simple Bencher Cab which does not want to start with anything, but when I take out the injectors and separate them from their position about 3 cm this part at the touch I put them back and do not want to start, 2 days ago I send him to clean the injectors and to change a benzine filter and lambda probe, he had stayed of a knob but now he died I would appreciate them a lot.: UNSURE:
13 years 8 months before #27329 by manual-mecanica
Manual-Mecanica response on the re: d21 starts with the injectors outside
It occurs to me for what you say that what I am aria drown would be to take out the injectors and send them to a test bank to see how they work if they do not close constantly defeat, as if to ensure their correct operation.
13 years 8 months before #27339 by manual-mecanica
The injectors have already sent them to clean and I imagine that when they clean them they should also calibrate them, anyway I will make them check too.
13 years 8 months before #27375 by manual-mecanica
Another symptom that I could see is that the four injectors work at the same time I do not see the order of 1-3-4-2.
10 years 4 months before #48619 by manual-mecanica
Hello friend, did you manage to solve the problem of your Nissan D21?
