Stratus 2000 Mexican Case
17 years 2 months before #2829 by manual-mecanica
Manual-Mecanica Answer on the Re: Stratus 2000 Mexican Case
Here in Torreon there are some stores called Auto Zone where you buy some liquids for the fuel that I think are called octane incrementors also recommended that you also apply a valve cleaner that is also empty in the tank but the bell did not take off, despite the fact that I followed the instructions to the letter, it is worth mentioning that I have always used premium gasoline
17 years 2 months before #2834 by manual-mecanica
I see that you have almost done everything for your vehicle and before you carry it with a sorcerer to make a clean tell me if the bell makes it in a minimum launch as in acceleration or if it does so in climbs or in velociad cruise since it can originate at a low precion in the oil pump, the knock sensor or detonation sensor is rarely Vehicle does not respond and the damage of this sensor is almost ovio since it is usually given because it is in contact with oil leaks and it cracks or bankruptcy and then begins in Dano in the sensor. Please tell me what conditions the bell presents.
MEXICO
APRIL 18 08
17 years 2 months before #2836 by manual-mecanica
I think that question is key and of course I am going to answer it, it turns out that as I discuss it before, the bell produces it once the engine reaches the temperature 1/2 of the indicator, which according to the electric is normal, and if I do not accelerate sudden Avenue where I do not have the preference then there if belling, to be more exact when I go from zero to 30 or 40 kms. In a space of 15 meters, I hope that this information helps you to help me a lot I will thank you.
Greetings to all and thanks for your answers.
17 years 2 months before - 17 years 2 months before #2853 by manual-mecanica
HI HOW ARE THINGS. How much you don't change the thermostat, you can approach a test. Remove the thermostat assemble again, fill it with water Remove the water outlet hose from the radiator side and start the car to see if the water with fuersa (this to check the water pump) if everything is well weapon everything and you can handle it one day or two without the thermostat as proof if the fault persists it is not due to overheating if it is composed installs a new thermostat \ "for me if it is overheat \" Eye with the radiator plug almost crazy to many with something like that since it loses the specifications over time. I encourage "the machines were thrown by man and for man \".
The test is when the heeeeee engine is cold.
Latest edition: 17 years 2 months before by .
