I have problems with the electronic transmission of a caravan 91, I already changed the relay and the input and exit sensors and suddenly works very well and from one moment to another the ignition current of the relayers is cut at that time I send direct current to the relay and yet the transmission remains blocked.
How blocked ??? are the changes work ??? It can be the problem of the transmission change solenoid block you can walk it by one of modern type only quitalo and replace it with the new one but you no longer put the plate that brings between the block and the transmission put it so directly only with 1 packaging
