Chevrolet Luv 2.2 liters acceleration failure
13 years 6 months before - 13 years 6 months before #28659 by manual-mecanica
Chevrolet Luv 2.2 liters acceleration failure published by Manual-Mecanica
Recently I acquired a Chevrolet Luv Motor 2.2 liters Chilean
completely unarmed mind manages to find all the engine spare parts and all the censors. The problem it presents is that it does not aselera as the engine should limit its ecleration in 2000 revolutions producing exhaust detonations. All the censors and the bovine are new someone could orar me I would like Saver what is the value in homios of the crankshaft sensor since in all the tests performed it points to the same
Latest edition: 13 years 6 months before by .
13 years 6 months before #28702 by manual-mecanica
Manual-Mecanica Response on the Re: acceleration failure Chevrolet Luv 2.2 liters
If you have detonations for the escape, the most caused thing is that it is tuning, but anyway that sensor is of efcto hall? How many cables do you have?
13 years 6 months before #28716 by manual-mecanica
The censor has three cables very similar to that of Corsa to the Optra and is not of Hall Action. I have already reviewed the time chain at the right points and the detonations are in high revolution in minimal this perfect mind without failures
12 years 1 week before #42139 by manual-mecanica
First a cordial greeting all the members of this forum.
After changing the computer, the injunctors, TPS sensor, MAP sensor, detonation sensor, bovine, gasoline bonb There to solve the problem, well, the problem was splicing that the homia heard was about 1.00 and not by devajo of 7.00 homios and also discovered something curious the Orijinal sensor comes polarisado and the sale as a renpluso comes normal mind invert
12 years 1 week before #42144 by manual-mecanica
The information is appreciated is very helpful for other forists lucky and abrasy.
