CHEVROLET MERIVA NAFTA PUMP
13 years 6 months before #29642 by manual-mecanica
NAFTA PUMP Chevrolet Meriva published by Manual-Mecanica
I want to change the Chevrolet Meriva 2006 electric pump and I have little idea of ​​how and practice too. I know how to get the hoses (which have a hitch) of inputs and outputs and the file of the electrical part; I cannot get the clamp that is put in a complicated position and also does not show well the type of fitting of any tool; I have tried some things but it is complicated, it must be easy, but when one does not know or is slow ... thanks from now
8 years 4 months before #52032 by manual-mecanica
Manual-Mecanica Response on the Naphrolet Meriva Naphta Pump
Same consultation, and same problem with the clamp ...
Josvil wrote: I want to change the Chevrolet Meriva 2006 electric gasoline pump and I have little idea of ​​how and practice too. I know how to get the hoses (which have a hitch) of inputs and outputs and the file of the electrical part; I cannot get the clamp that is put in a complicated position and also does not show well the type of fitting of any tool; I have tried some things but it is complicated, it must be easy, but when one does not know or is slow ... thanks from now
8 years 4 months before #52035 by manual-mecanica
Hello friend look to disassemble a pump you must have tools to unlock the connectors you must be careful or you could break the connectors greetings
