Putting a renaul 19 diesel
13 years 5 months before #30458 by manual-mecanica
Putted of a 19 Diesel renaoul published by Manual-Mecanica
Someone could help me by facilitating some manual or guide, how to put a renault 19 diesel engine.
13 years 5 months before #30476 by manual-mecanica
Manual-Mecanica response on the Re: tuning of a 19 diesel renaoul
Hello, the crankshaft in the block near the box changes there is a plug that introducing an 8 mm spike enters a counterweight and marks the PMS, the pump if it is Bosch is covered with an 8 threaded screw in the block and past in the right side of the pinion, if it is cav or broken diesel is threaded on the left side of the pinion takes to the left kick and the camshaft has a brand in the upper Piñón If you place an original strap, the belt brands put it ready
13 years 5 months before #30483 by manual-mecanica
Hello again, we are going to explain it better, next to the oil level rod near the box changes there is a screw that is a cap is released and a pin or pointer of 8 mm in diameter is introduced or the Renault 1054 useful and we push it soft, we turn the engine to the right until it enters, it does so in a hole of the counterweight of the crapper that will give us the PMS. Of cams that have a granetazo in a tooth, it has to look at the top and match the fixed index of the plastic lid that covers the belt, the pump pinion has two marks B and R the B corresponds to the Bosch pump and the broken diesel r or r of the pump of the pump injectoray the pointer inside the crankshaft. Greetings
10 years 3 months before #48904 by manual-mecanica
Manual-Mecanica Response on the subject of a 19 Diesel renaul
Hello someone could send me photos of how the point of my bosh injection bomb is left .. It is the only thing I lack a 1.9 Diesel R19
thanks ..
