Help with my Peugeot 206
13 years 5 months before #30763 by manual-mecanica
Help with my Peugeot 206 published by Manual-Mecanica
:( Hello HCicos I need your help, I have a Peugeot 206 and the band was burst. I can't find one position diagram, can you help me?
13 years 5 months before #30911 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with my Peugeot 206
What engine is the Peugeot? Each type of engine has different tuning
13 years 5 months before #30914 by manual-mecanica
If Peugeot is the 206 year 2006 onwards, the setting is very simple -.-. I explain it to you:
.. The piston one will be number 4 put it in its PMS.
.. At the camshaft pulley you will see a hole look for a bolt or screw that calms perfectly when the arvol pulley holes coincide and another hole that brings in the engine head will be on time.
.. Of course before blocking with the bolt check the PMS of your piston four.
.. If it does not swallow in the Sigual K it usually happens in some cases marks with a tall or ink so as not to lose the synchronization.
_Tips. Mark the direction of turn of the Obanda de Distribution Correa if you are not going to replace it.
__No disconnect the computer, you still side. The harnesses of this are somewhat problematic.
_ You can decone the battery in this car, nothing is distrusted .--
pleasure in helping you, It is my email because we all need everyone.
13 years 5 months before #30915 by manual-mecanica
The above mentioned is linked to a person k is dedicated to the world of mechanics since the same luck is indispensable.
13 years 5 months before #30916 by manual-mecanica
The above mentioned is linked to a person k is dedicated to the world of mechanics since the experience itself is indispensable
