Abs Abs Aveo 1.6
13 years 4 months before #31590 by manual-mecanica
ABS AVEO 1.6 BRAKES PUBLISHED BY MANUAL-MECANICA
Friends a help I have a bird 1.6 with a problem in the left front sensor of the ABS, I have no code but the light is turned on in the scanner show me all the 4 sensors three of them in 0 km/hy the left in 225 km/h, I already change the sensor and the same thing already looks at the installation is healthy no longer I will be done that will be more computer
Profile 1 second before • I like • Comment
13 years 4 months before #31595 by manual-mecanica
Manual-Mecanica Response on the Re: AB AB AVEO 1.6 brakes
I greet the Colombian brother first disconnect to the battery. Then disconnect the ABS you wait a few minutes later connect the battery the suiche and without connecting the ABS then connects the ABS, you turn off and then you turn it on if you follow the fault will have to loosen the brake tap of the left front wheel and when the fluid x comes out for a few seconds, you tranc
11 years 7 months before #44039 by manual-mecanica
Manual-Mecanica response on the topic brakes Abs Aveo 1.6
First, lower the wheels and clean the sensors that x dust, fat, etc. They do not make good contact and then erase the fault with the scanner. If the witness persists and if not, code appears in the scanner or 5200 appears the fault is related to a failure in the motor circuit Q controls the traction. for which you must download it and review it.
