Power loss Citroen C3 1.4 HDI of 2003
13 years 3 months before - 13 years 3 months before #32329 by manual-mecanica
Power loss Citroen C3 1.4 HDI of 2003 published by Manual-Mecanica
Hello very good. Well, if you can help me ...
the C3 of a relative has a problem, and that is that when I drive it I feel very loose, as if the turbo does not work, and in the slopes a bad thing falls down, I know that from that engine you can not ask much but I have taken other equal cars and with the same engine and have much more thrust.
What can happen to you?
Gracian in advance, greetings
Last edition: 13 years 3 months before by . Reason: more written word
13 years 3 months before #32342 by manual-mecanica
Manual-Mecanica Response on the Re: Power Loss Citroen C3 1.4 HDI of 2003
A question based on what you say about the loss of power, have you noticed if it makes any noise? I mean something like a Pam Pam Pam Pam, when it works. Not a metallic noise, but a noise in the operation that increases as you accelerate
13 years 3 months before #32349 by manual-mecanica
Hello, first you have to go to the basic:
---- revision ????
How long it takes without changing fuel filter ...
The loss of power may be due to several factors but if no light is lit in the painting, an injector or the famous flow rate can also be due ...
For an online diagnosis we must know some more data to be able to guide you (scarce motor noises or irregular slowdown behavior ..)
13 years 3 months before #32359 by manual-mecanica
I have seen several citroen and when it is not for tuning it is for the obstructed escapes, now if they have never done anything there to eat
13 years 3 months before #32361 by manual-mecanica
Very good, for what you tell, all the problem you can have is of the caudalimetro or you can also have the obstructed catalyst, although you do not say the km that the car has.
Greetings and I hope this helps you.
