Power loss Citroen C3 1.4 HDI of 2003
13 years 4 months before #32394 by manual-mecanica
Manual-Mecanica Response on the Re: Power Loss Citroen C3 1.4 HDI of 2003
Well, no strange noise neither anything nor fumes nor anything that is what we can make me a little, thanks Sertdi
13 years 4 months before #32395 by manual-mecanica
Ddlcsa, because no light in the painting, no strange noise, an injector failed him a year ago and was solved, I also thought of the caudalimetro but I will be tasting with other things until I reach the flow that has to cost a paste, that if ... the filter of the diesel I have never changed it, I think it is time to change it.
13 years 4 months before #32396 by manual-mecanica
clogged escapes? Is it another option, then I will look at it when I have a little time to meet. Thank you kikemec
13 years 4 months before #32397 by manual-mecanica
Hi Jose.P, because it already has 130,000km ... something has to have full of carbon / hehehe, I will first change the filter of the diesel later I will look at the EGR and the whole theme, the escape too and the caudalimetro. But when the flow failure the flow does not come out any witness in the painting ???
Thank you very much to all you are machines !!
13 years 4 months before #32419 by manual-mecanica
The truth is that most of the time when the flow rate fails, it indicates nothing and the only way is to try it on the road with the diagnostic machine, although if you never made a revision in due conditions (air filter, diesel filter) you already know the first thing you should do before putting yourself with major problems.
Greetings.
