Ford Transit Smoke White
13 years 3 months before #33142 by manual-mecanica
Ford Transit Smoke White published by Manual-Mecanica
I have a Ford Transit 2.5 Td wash the engine, and now a lot of white smoke comes out for the exhaust and it does not accelerate, I have changed the injection pump and keep doing the same thing that I can do more?
13 years 1 month before #34934 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Transit HMO White
If your car has made white smoke, it is most likely that it is water in the fuel because injection advance cannot be because the pump you already changed and point it can not be because the fault was already there before changing the pump I do not think that the injectors have been danced you can put a galonera with oil and hoses as if it were the tank purges the pump well and starts if the problem is how I said water
